15 years agoELF file fails to load
I just did a clean install of v.10 development tools for Quartus and NIOS on my Windows 7 32-bit machine. The tools are running in Admin mode and I am able to download the .SOF file to the board using the USB byteblaster.
In to run my source file, I have to select Ignore mismatched system ID and Ignore mismatched system timestamp. A dialog box opens and says the Download Elf process failed. The message that I get in the console is Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused help is appreciated
