I am using the 50 MHz clock and trying to run a simple processor interface which should load without a problem.
The reset line is connected to SW9 and I keep it high to allow the processor to load just like I did in previous versions of the tool.
For a sanity check, just to see if it was a Win7 problem, I downloaded and installed the V10 on XP.
It gave me errors again on the Time Stamp and System ID but does think it is loading the ELF file. After toggling the SW9 it does fail to load as expected.
However, the problem on the XP is the code doesn't do anything so I still think there is a problem.
My suspicion is the JTAG interface to NIOS is flakey :cool: .
