10 years ago
Edit IP Components in Quartus 16.0
Question about edit "IP Components" in Quartus 16.0 -
Want to edit the previous entered the IP components. But the "Edit in Parameter Editor" is grayed out -
1. May I have to close then re-open the Quartus 16.0 in order to do it?
2. Any other way to edit the IP components?
Please advise.
Thanks!
    I think that components can only be edited in the version that they were created in. They can then be imported into other projects, or re-created in a newer version.
    You should have an option to "Upgrade IP Components..." under the "Project" menu. This will only work for IP components that remain supported in Q16 - components do get dropped. Following a successful upgrade I'd hope you're able to edit the component.
    Cheers,
    Alex
