9 years agoEdge detection asynchronous signal fails
Hello, I am working on a fairly simple VHDL design where I am trying to detect the rising_edge of an input. Whenever a rising_edge is detected I want to multiply another input by 2 and output ...
9 years ago --- Quote Start --- They work exactly as you expect the underlying hardware to work. This example is fairly pointless - as it would set the output to all 1s when some data_ready input is '1', so you've built a latch because it does not have an else clause. The after keyword is purely for simulation. It has no meaning in a real circuit as absolute delay elements do not exist. They are meant to model the propogation delay that may occur in a real circuit. They will be removed for synthesis (with associated warnings). So unless you want them for modelling purposes, do not use them. If you have a synchronous design you will never need them. --- Quote End --- Thanks for the clarification!
