11 years ago
EDA netlist writer problem
Hello all,
I have got a problem with Quartus II 10.1 (which I run on Windows 8).
My goal is to load a simple VHDL-design into a cyclone IV (EP4CE22F17C6N) FPGA
Analysis and compile work perfectly. However the EDA netlist writer returns this message :
"... cannot generate output files. Specify command-line options to generate output files, or update EDA tool settings using GUI or Tcl script."
I got the feeling I am stuck! Can somebody help me?
Thanks in advance.
Eric
the Netherlands
    You can try with the latest Quartus II 15.0 to see if issue still persist.
    --- Quote Start ---
    You are welcome.
    --- Quote End ---
    OK, in order to avoid a lot of problems with insufficient support:
    I installed Quartus II 10.1 on a Windows 7 platform.
    However, I get the same error message when I execute the EDA netlist writer:
    "Warning: Can't generate output files. Specify command-line options to generate output files, or update EDA tool settings using GUI or Tcl script."
    (this should not be of any influence, but maybe it is good to mention: I am working with the DEO-nano FPGA board plus included Quartus installation DVD / distributor Terrasic).
    What is wrong here?
    Kind regards
    Eric
    Hi Eric,
    Do you have a chance to try with the latest QII 15.0 to see if similar issue exist? If yes, then probably you might want to consider filing a ticket to Altera to seek clarification.
    Hi Tiny,
    Thank you. Yes, that seemed to me also the next step to investigate this problem.
    Maybe the problem is the 32-bit and 64-bit system?
    When I try to install QII 15.0 the installer replies a message that QII 15.0 can not be installed on a 32-bit Windows 7 platform. I have installed QII
    ignoring this message.
    Has anyone experience with this kind of problem?
    Kind regards
    Eric
    I have installed some Windows 8.1 updates and everything seems to be working correctly. Thanks.
