11 years agoEDA netlist writer problem
Hello all, I have got a problem with Quartus II 10.1 (which I run on Windows 8). My goal is to load a simple VHDL-design into a cyclone IV (EP4CE22F17C6N) FPGA Analysis and compile wo...
11 years ago --- Quote Start --- You are welcome. --- Quote End --- OK, in order to avoid a lot of problems with insufficient support: I installed Quartus II 10.1 on a Windows 7 platform. However, I get the same error message when I execute the EDA netlist writer: "Warning: Can't generate output files. Specify command-line options to generate output files, or update EDA tool settings using GUI or Tcl script." (this should not be of any influence, but maybe it is good to mention: I am working with the DEO-nano FPGA board plus included Quartus installation DVD / distributor Terrasic). What is wrong here? Kind regards Eric
