Oliver_I_Sedlacek
Contributor
2 years agoEclipse problem nios2-elf-gcc command not found
I know there's an older very similar thread but the links to suggested solutions are now broken. I've got myself a shiny new PC but I can't do any NIOS2 Eclipse work on it because I'm getting this p...
EBERLAZARE_I_Intel
2 years agoHi,
What is the PC environment on your old PC vs the new PC?
On another note, it seems to be the Nios II might be calling the "nios2-elf-gcc" instead of "nios2-elf-gcc.exe" for Windows.
Could you try to open the nios II SBT/eclipse from Nios II command shell?
In the Nios II command shell, run "eclipse-nios2.exe".
