18 years agoIt is indeed as Bobf said. If you use Vhdl, you can also use "map" sentence to connect two different signals, pins, and ports.
I always use vhdl and find it well. How about posting an example about the use of HDl language, which the same signal names could be connected automatically. Thanks.
