18 years agoI'm going to assume you're using the schematic design tool here. If you use an HDL language using the same signal name will automatically connect two signals. I haven't used the schematic tool in a long time but it used to work that if you draw a dangling net, or bus, off a component pin and give it the same name as another dangling net, or bus, the connection would be automatically made. Note that it won't, or didn't, draw a line between the two but did connect via naming attribute.
