12 years agoEarly Power Estimator Problem
I'm trying to run the cyclone IV EPE. On starting, after the enable macros pop-up, Excel announces Run-time error '429' ActiveX component can't create object. From here, the spreadsheet basically does not work. The Excel version is 2002 SP3, which should be in the acceptable range. I have run the repair function. The maxII version and stratix II version run OK, the stratix iii/iv version does not - same problem. Searching the forum for epe produces no results, searching for epe error produces lots, but only for error. Sorry, do not have access to other version of Excel. Any ideas? S.
