Altera_ForumHonored Contributor17 years agoDynamic counter values for PLL Hello, I'd like to know if there is a way to dynamically set the values for the M, N and P counters,for the Stratix II PLLs, by linking them to some registers. I see know that I can just set...Show More
Recent DiscussionsCompile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusIIConnection bit order between hierarchy
