LLeta
7 years agoDuring “Analysis & synthesis”, the Quartus Pro 17.1.2 Build 304 (Patch 2 installed) can’t recognize and load the right “.mif” file which is already specified in the VHDL code via the "attribute ram_init_file".
I got the following message: Warning(127007): Memory Initialization File or Hexadecimal (Intel-Format) File "E:/MyProject/qdb/_compiler/top_rtl/root_partition/17.1.0/partitioned/1/mifs/ram3_generic_...
JoanneSinY_L_Intel
7 years agoHi,
Can you try to work around by creating soft link from your source file and update the qsf file. The steps is mention in the link below
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/rd04032012_240.html
In a mean time, is this possible to share the design for us to replicate the error above and workaround the issue as well?
Joanne
- LLeta7 years ago
Thanks Joanne for your reply.
But, it still not working.
Please find attached an archive of my example design.
