Hi bertulus ,
i did as you said , i duplicate the black box N times with all input and output ports .
about the clocks , the issue is that there is one clock input to the design and i used 1 PLL at the new vhd file.
The PLL has 2 output - c0,c1 that connected to each black box ,
The design has more than one black box and need to connect the PLL outputs (C0,C1) to each one of them .
i defined 2 signals of std_logic_vectors(1 downto 0) - PLL_lock_25M,PLL_lock_100M and connect them at the for generate loop :
dup : for i in 1 to 2 generate
one: Design port map
clk_in_25M => PLL_lock_25M(i-1)
clk_in_100M => PLL_lock_100M(i-1)
end generate ;
at the PLL instantiation i wrote :
pll1: entity.pll (behave) ... port map (
c0 => PLL_lock_25M
c1 => PLL_lock_100M
after compilation there is error at this section because c0,c1 are std_logic and PLL_lock_25M,PLL_lock_100M are std_logic_vector and the instantiation doesn't succeed .
what do you recommend to do ?
