The new code shown will write the value 0x0000000C to address 0 continuously.
In the code:
else
q <= '0';
--if ( av_m_read_n = '0' and av_m_address = b"0" ) then
--av_m_readdata <= reg_temp;
--elsif ( av_m_write = '0' and av_m_address = b"1" ) then
av_m_write <= '1';
av_m_chipselect <= '1';
av_m_byteenable <= "1111";
av_m_address <= b"0_0000_0000_0000";
av_m_writedata <= X"0000000C";
av_m_address <= b"0_0000_0000_0001";
av_m_address <= b"0_0000_0000_0010";
av_m_address <= b"0_0000_0001_0000";
av_m_address <= b"1_1111_1111_1111";
--av_m_address <= b"0_0000_0000_0011";
--av_m_writedata <= X"0000000C";
av_m_write <= '0';
av_m_chipselect <= '0';
av_m_byteenable <= (others => '0');
end if;
the synthesiser will only honour the 'last' assignment for each signal, thus of al the address assignments in the above code :
only the very last will be synthesised as it 'wins'.
If you want to do multiple writes you have to do a write per clock cycle and you have to understand sequential coding: I suggest you read pages 91-121 of V. Pedroni's book "Circuit Design with VHDL".
