I aligned the compare value to the databus width and now reading works perfectly !!
But i still do not understand why i cannot write.
At the beginning of the process i assigned the control signals, then the address where i want to write and then the data.
After all the transfers i set the control signals to zero. But is this sequential approach correct?
I thought the RTL viewer shows only the last state of the signals, so the values are actually ok.
When i keep the control signals all the time on high level the RTL shows the correct assignments, but the memory is still empty.
https://www.alteraforum.com/forum/attachment.php?attachmentid=8987
avalon_if : process (reset_n, clk)
begin
elsif clk'event and clk ='1' then
av_m_write <= '1';
av_m_chipselect <= '1';
av_m_byteenable <= "1111";
av_m_address <= b"0_0000_0000_0000";
av_m_writedata <= X"0000000C";
end if;
end process avalon_if;
