9 years agoDSP Block Balancing settings using OpenCL
I am trying to compile a multi-kernel file in which one kernel, say A, has 16-bit arithmetic operations. What I see is when I change various parameters in other kernels, DSP usage in kernel A sometim...
9 years agoYou can try compiling with -g if you haven't tried that. Are you able to use 16.1? You may get some more information.
