9 years agoDSP Block Balancing settings using OpenCL
I am trying to compile a multi-kernel file in which one kernel, say A, has 16-bit arithmetic operations. What I see is when I change various parameters in other kernels, DSP usage in kernel A sometim...
9 years agoThanks for referring to analyze-area. I have been able to extract more resource information. The short answer is yes compiler was auto-unrolling and with unroll 1, it was being limited and restricted the DSP usage.
There are still some terms in the area report that I do not understand e-g different block names for.condX.i.preheader, for.bodyY.i, for.endZ.i, where X, Y, Z are random (for now) numbers that I think are because of nested loops in source code but I have not been able to make complete sense of so far. Also it describes resource usage for 'No Source Line' multiple times that I am not sure represents what.
