9 years agoDSP Block Balancing settings using OpenCL
I am trying to compile a multi-kernel file in which one kernel, say A, has 16-bit arithmetic operations. What I see is when I change various parameters in other kernels, DSP usage in kernel A sometim...
9 years ago --- Quote Start --- No unfortunately I only have version 15 and it does not generate the HTML report. I saw the log report but it only show messages concerning pipeline and data dependencies. It is not showing anything regarding unrolling. --- Quote End --- you should be able to run aocl analyze-area to view the report with version 15. I'd be interested to see what you find
