9 years agoDSP Block Balancing settings using OpenCL
I am trying to compile a multi-kernel file in which one kernel, say A, has 16-bit arithmetic operations. What I see is when I change various parameters in other kernels, DSP usage in kernel A sometim...
9 years agoIf the compiler automatically unrolls a loop and you use the "-v" switch, you will see a message in the log about the automatic unrolling. You can see resource utilization per line of your code in the HTML report (if you are using Quartus v16 and above).
