9 years agoDSP Block Balancing settings using OpenCL
I am trying to compile a multi-kernel file in which one kernel, say A, has 16-bit arithmetic operations. What I see is when I change various parameters in other kernels, DSP usage in kernel A sometim...
9 years agoThat is an interesting observation. The only case I have seen that having a# pragam unroll 1 before a loop will have an effect is when the compiler decides to automatically unroll that loop, and adding that pragma would prevent it.
