18 years agoUnder your synthesis directory, DSE creates a directory called dse.
Depending on how you have the settings setup, there may be multiple directories under that. But usually there is a best.qar file. This is a Quartus Compressed file that contains the best results you received from the DSE run. Double click on this file, and Quartus will ask you where you want to restore the project. (Default is ./synthesis/dse/best_restored) In that you will find the .pof .sof and .rbf files for that particular run. Pete
