DSE - How to setup remote server with SSH
I am trying to setup a PC as remote farm for DSE compilations.
Currently I am getting the following:
Warning: [Errno 11001] getaddrinfo failed
Error: [Errno 11001] getaddrinfo failed
Error: Traceback (most recent call last):
File "server.py", line 103, in run_impl
File "f:\intelfpga\18.1\quartus\common\python\lib\socketserver.py", line 430, in __init__
self.server_bind()
File "f:\intelfpga\18.1\quartus\common\python\lib\socketserver.py", line 441, in server_bind
self.socket.bind(self.server_address)
socket.gaierror: [Errno 11001] getaddrinfo failedSettings Client side (Windows 10 - Quartus 18.1):
I tried all settings, where there is a reference to the remote PC with the IP address and hostname and tried all possible combinations.
The IP address looks like no LAN IP address, but it is a LAN IP address - Network: 192.9.200.0/24 the remote and local PC are in the same sub.
- Hostnames: Chattanooga-PC
- Quartus Root Path: C:\intelFPGA\18.1\quartus - tried with \\ and // at the beginning - This is the quartus folder on the remote PC
- SSH Client: made different attempts to use plink, with full path, with .exe and without any synthax
- Farm Operating System: windows
- Local to Remote Path Mapping: [Local path];[Shared Folder] - where [Shared Folder] is accessable from my local PC - with and without // at the beginning
- initial Working Directory: [Shared Folder]
Settings remote PC Windows 10 Quartus 18.1 with Trial license
- OpenSSH Server with optional Windows Features enabled
- SSH connection from local to remote PC is possible with putty
* Additional comment: I read some entries which mentioned the setup video: I got the same feeling, there is SSH mentioned but there is nowhere enough information to SSH in the video and it would be nice to know if it's even possible to use windows with LSF or how to test the cygwin ssh commands.
Also the Post editor in this forum is not to my liking. You click one time in the wrong place and the whole question is lost and the editor window is too small.
- KhaiChein_Y_Intel
Can you follow the steps in How to setup Remote farm machine in Design Space Explorer II video published by Intel FPGA and let me know at which stage you see the error?
https://www.youtube.com/watch?v=WdO5VOQkl7s
Please let me know if you have any questions.
- KhaiChein_Y_Intel
Can you try setting the Host value to "127.0.0.1" from within the DSE Server Settings section of the Exploration tab in the DSE II GUI?
- GK4
What I haven't done: Using keys for the SSH connection.
I have to wait for the IT to configure the SSH keys.
For the 127.0.0.1 setting, I put in: Exploration => Registartion Host = 127.0.0.1 Registration Port = 0 on the client PC.
Same result.
Is there anything else I can try in the meantime?
- KhaiChein_Y_Intel
Have you tried to set this in the .dse file?
- GK4
We tried some SSH settings on the remote Windows host, still no success.
Currently we are setting up a Linux machine, but this will be done next week.
Can you clarify where i have to set this in the .dse file?
- KhaiChein_Y_Intel
You can add the following in the .dse file
host=127.0.0.1
- GK4
Ok, after various tries, we stopped trying to get the DSE running and resorted to manually archive the project and extract it on the remote host.
Adding the host=127.0.0.1 line resulted in a different error message:
Failed to connect to [remote host]. If private key is encrypted, please run ssh key agent first
I tried different client software fro connecting to the host with the private key i gave the DSE client and all were successfull.
I added the path: \\C:\Users\[Local user]\.ssh\id_rsa , same result with: ~/.ssh/id_rsa - Then i switched the \ to a / and i got the error:
Unable to open connection, host does not exist. Tried with hostname and IP Address.
- KhaiChein_Y_Intel
Can you try
1) run
plink -i fpgauser.ppk -l root <remote host> -P <port>
first and accept the host's fingerprint.
2) After confirming the fingerprint, rerun:
Confirm that you can connect to remote host without being prompted about password and without prompted to accept host fingerprint or any other prompts. Plink should directly go to the remote host's prompt. If there any other prompts, please let us know. If you can confirm there are no further prompts, try the same host using DSE.
- KhaiChein_Y_Intel
Do you have any updates?
- GK4
We stopped trying to get it running.
