GK4
7 years agoDSE - How to setup remote server with SSH
I am trying to setup a PC as remote farm for DSE compilations. Currently I am getting the following: Warning: [Errno 11001] getaddrinfo failed
Error: [Errno 11001] getaddrinfo failed
Error: Traceb...
KhaiChein_Y_Intel
7 years agoHi,
You can add the following in the .dse file
host=127.0.0.1
- GK47 years ago
Ok, after various tries, we stopped trying to get the DSE running and resorted to manually archive the project and extract it on the remote host.
Adding the host=127.0.0.1 line resulted in a different error message:
Failed to connect to [remote host]. If private key is encrypted, please run ssh key agent first
I tried different client software fro connecting to the host with the private key i gave the DSE client and all were successfull.
I added the path: \\C:\Users\[Local user]\.ssh\id_rsa , same result with: ~/.ssh/id_rsa - Then i switched the \ to a / and i got the error:
Unable to open connection, host does not exist. Tried with hostname and IP Address.
