16 years agoDownloading Elf Process failed
Help. I went home last night with everything working fine. I came in this morning and can't get the Nios II processor embedded in my Stratix III FPGA to download from the Eclipse environment. ...
13 years agoHi,
i had the same problem. In my case I had an external PLL which was resetted, too. Maybe it took to much time to get a lock again and the Connection failed. I solved it by not allowing the system to reset before downloading the ELF File. Its a checkbox in the IDE under Run../Run Configuration/Target Connection/"Reset The Selected Target System". Untick it and it works. ;)
