16 years agoDownloading Elf Process failed
Help. I went home last night with everything working fine. I came in this morning and can't get the Nios II processor embedded in my Stratix III FPGA to download from the Eclipse environment. ...
16 years ago --- Quote Start --- That was it. I had made an innocuous change to the reset signal to two off-chip devices. I undid that change and now things work. I can't say that what I changed makes sense (since the on-chip functions, including the CPU, are unaffected), but it works. Thanks for taking the time to reply. --- Quote End --- Hi I'm currently experiencing the same problem you had. Where did you make those changes? In the .bdf file or in the PLL component in the SOPC builder?
