9 years agoDownloading ELF Process failed when executing from flash
Hi, I am using Eclipse to program my Nios on a Max10 FPGA. When I run the Nios code from the RAM everything works fine. Now I changed everything so that the code would execute directly from the...
SDevaux
6 years agoHello,
I have the same problem, everything go right when I program via Quartus Programmer in pof.
I can run it from SBT, but if I change something in my C Code, I have to rebuild pof, program UFM and then I can launch it from SBT Run "NiosII hardware".
Seems that SBT can have access to UFM in write mode.
did you have an ansewer from Intel?
