12 years agoThanks for your feedback.
Unfortunately, what you suggest is not what I am trying to achieve. I want to run a JTAG session and NOT program an external flash such as the ECPS.(unless I mis-understand some feature of the nios-flash programmer) I can upload the sof over JTAG using the quartus_pgm.exe so the firmware is no problem. My problem is directly programming the SDRAM(it could also be onchip memory for other projects) over JTAG and then executing the code. I would then want to run a nios2-terminal to get messaging over the JTAG-UART. I appreciate this configuration is then lost after a power cycle and will revert to the production image in the EPCS device. (which is exactly what i want)
