18 years agodown counter
y guys,
I have to code for the down counter. As u know , the down counter will take the data in put when the load is high( level trigger) and then when the load is low , they start to count down which is control by the "clock" . As i know is the "load" will be level trigger and the clock will be edge trigger. The thing is , usually my frequency of the load usually less than the clock . For example , if i have the load frequency is 10khz , and suppose my data is 3 bits , then the clock frequency will be 2^3 * 10khz. It help me every (f= 10 khz) to take the data and then count down . So the problem i facing is since the load is level trigger , then the counter start to count if the load is logic high----> some edge trigger clock , data wont count dow ---> that is not what i want.. I want it they load the data in and then the next cycle of the clock , they start to count down . ( to make sure that every value data load in , they will count down and reach zero) Some suggestion is "load" signal , not using the 50% duty cycle, but then if i have 8 bits data , then the clock will be 2^8 times the load , then the load will be very small duty cycle. So i create the new code , to procuce the signal S1 to act like the load signal. But there is some warning about " Timming analysis is analysing one or more combinational loop as a latch ( which is tmp signal in the below code)" and " found 3 nodes in clock path at the ripple or gate clock..." Here is the code : the S: load signal and C is the clock signal, D is datain , Q is data out process (s, c) isbegin
if c'event and c = '0' then
s2 <= not s;
end if;
end process;
s1 <= s and s2;
process (s1, c, d)
begin
if s1 = '1' then
tmp <= d;
elsif (c'event and c= '1') then
tmp <= tmp - 1;
end if ;
end process;
q <= tmp;
end behavioral; I use the quartus II software. I am new in VHDL . Another problem , in this code i also want to take the S1 out , that is why i declare it as inout . So i can create the symbol for this code , and the use in the schematic. But when i run the compile , there is one warnning : " S1 is missing source signal" . How can i overcome it ? Regards. clark Regards
