Does Quartus 18.0 support the VHDL 2008 'ELEMENT attribute?
I am using the VHDL 'ELEMENT attribute to determine the range of an element in an array.
ReadRegisterData: process (REG_CLK) is
begin
if (rising_edge(REG_CLK)) then
i_RegReadData <= (others => '0');
if (REG_RDEN = '1') then
case? i_RegSelect is
when "1---" => i_RegReadData(0) <= i_InterfaceSelect;
when "0100" => i_RegReadData(i_DAC_CodeWordMaskReg'ELEMENT'RANGE) <= i_DAC_CodeWordMaskReg(0);
when "0101" => i_RegReadData(i_DAC_CodeWordMaskReg'ELEMENT'RANGE) <= i_DAC_CodeWordMaskReg(1);
when "0110" => i_RegReadData(i_DAC_CodeWordMaskReg'ELEMENT'RANGE) <= i_DAC_CodeWordMaskReg(2);
when "0111" => i_RegReadData(i_DAC_CodeWordMaskReg'ELEMENT'RANGE) <= i_DAC_CodeWordMaskReg(3);
when others => null;
end case?;
end if;
end if;
end process ReadRegisterData;Quartus reports the following error:
Error (10482): VHDL error at <file>.vhd(176): object "ELEMENT" is used but not declaredfollowed by the error message:
Error (10406): VHDL attribute error at <file>.vhd(176): object with attribute "range" must have scalar or array typeDoes this mean that Quartus Prime Version 18.0.0 Standard Edition doesn't support this VHDL 2008 feature?
- MuhammadAr_U_Intel
Contributor
Okie I have checked, this seems to be a discrepancy in document "https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/br/br-quartus-prime-software.pdf?language=en_US" I will share this to our internal team.
Quartus Standard has a very limited support for VHDL2008, and hence it is recommended to switch to Quartus Pro for enhanced VHDL2008 support.
Arslan
- corestar
Contributor
@MUsman, I can confirm that @Tricky is correct because I'm actually using VHDL 2008 in Quartus Prime Standard 18.0.
Your recommendation to switch to Quartus Pro has a problem; Quartus Pro only supports a limited number of high end chips (Stratix 10, Arria 10, Cyclone 10 GX)! We're using Cyclone V and are forced to use Quartus Standard.
I found a note in the Quartus Primt Std User Guide that seems inconsistent with this not to mention the body of the guide itself. Hopefully, this is not yet another indication that Intel intends to abandon lower end markets.
