JDe_S4
8 years agoDoes Quartus 18.0 support the VHDL 2008 'ELEMENT attribute?
I am using the VHDL 'ELEMENT attribute to determine the range of an element in an array. ReadRegisterData: process (REG_CLK) is
begin
if (rising_edge(REG_CLK)) then
i_RegReadD...
corestar
Contributor
8 years ago@MUsman, I can confirm that @Tricky is correct because I'm actually using VHDL 2008 in Quartus Prime Standard 18.0.
Your recommendation to switch to Quartus Pro has a problem; Quartus Pro only supports a limited number of high end chips (Stratix 10, Arria 10, Cyclone 10 GX)! We're using Cyclone V and are forced to use Quartus Standard.
I found a note in the Quartus Primt Std User Guide that seems inconsistent with this not to mention the body of the guide itself. Hopefully, this is not yet another indication that Intel intends to abandon lower end markets.
