10 years agoDoes modelsim_ae 15.1 support sparse memories?
Folks, Does modelsim_ae 15.1 support sparse memories? If it does, how is it accomplished? If it does not, what upgrade paths are available (SE, Questa, VCS, Incisive, etc) to get spar...
10 years agoA sparse memory is a large memory (reg [7:0] mem[(16*1024*1024):0]) where only a few locations are accessed during simulation.
Before SystemVerilog simulators were able to deal with this and not require a large amount of memory to be allocated on the host system. (VCS and NCsim deal with this automatically.) This has also been called "dynamic memory". Here is a link that explains the SV way to do it: http://www.asicguru.com/system-verilog/tutorial/assoc-arrays/72/ Modelsim AE seems to fail on large Verilog 2000 style memory declarations liek above: # do modelsim.do# vsim -novopt -L work test # Start time: 09:33:47 on Apr 06,2016# // ModelSim ALTERA 10.4b May 27 2015 Linux 2.6.32-504.23.4.el6.x86_64# //# // Copyright 1991-2015 Mentor Graphics Corporation# // All Rights Reserved.# //# // THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION# // WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION OR ITS# // LICENSORS AND IS SUBJECT TO LICENSE TERMS.# // THIS DOCUMENT CONTAINS TRADE SECRETS AND COMMERCIAL OR FINANCIAL# // INFORMATION THAT ARE PRIVILEGED, CONFIDENTIAL, AND EXEMPT FROM# // DISCLOSURE UNDER THE FREEDOM OF INFORMATION ACT, 5 U.S.C. SECTION 552.# // FURTHERMORE, THIS INFORMATION IS PROHIBITED FROM DISCLOSURE UNDER# // THE TRADE SECRETS ACT, 18 U.S.C. SECTION 1905.# //# Loading work.test# ** Fatal: (vsim-4) ****** Memory allocation failure. *****# Attempting to allocate 16777240 bytes# Please check your system for available memory and swap space.# ** Fatal: (vsim-4) ****** Memory allocation failure. *****# Attempting to allocate 16777224 bytes# Please check your system for available memory and swap space.# ** Warning: (vsim-3116) Problem reading symbols from /home/tools/altera/15.1/modelsim_ae/linuxaloem/vsimk : can not allocate memory for reading ELF file. Our host has 24G of physical memory and it's mostly free (20G) when we run the sim. So I don't think the error message is very accurate. This is annoying.....but we've modified the legacy code and used SV style declarations to fix this. Regards, John Pavan
