8 years agoDocumentation for non-latest Intel FPGA SDK for OpenCL
I recently got a Nallatech board whose BSP was created with tools v.17.1. Therefore I plan to use same SDK version and review the corresponding documentation. However, the documentation I could find online on the Intel/Altera websites corresponds to the latest one (18.0): * https://www.altera.com/products/design-software/embedded-software-developers/opencl/support.html * http://dl.altera.com/opencl/17.1/?edition=pro&download_manager=dlm3 I was wondering if someone knows a page where I can find all documentation related specifically to the v.17.1. Thanks! Leo4 Replies
I am not sure if Altera keeps the older documents anywhere that is publicly available. I have the Programming and Best Practices guides from v17.1 and have attached them to the post.
--- Quote Start --- I am not sure if Altera keeps the older documents anywhere that is publicly available. I have the Programming and Best Practices guides from v17.1 and have attached them to the post. --- Quote End --- Many thanks HRZ! - Altera_Forum
There is a documentation archive link on the support page. You can search by title of document but that may not give you the best results. Use the document part number from the current doc, usually on the front page, and copy that to the search box to get previous versions.
--- Quote Start --- There is a documentation archive link on the support page. You can search by title of document but that may not give you the best results. Use the document part number from the current doc, usually on the front page, and copy that to the search box to get previous versions. --- Quote End --- Thank you, Desert Rats, It works. E.g. previous versions of the best practices guide: https://www.altera.com/bin/search?q=ug-ocl003&client=www_doc_archive&output=xml_no_dtd&proxystylesheet=www_doc_archive&ie=utf-8&sort=date:d:l:d1&entqr=3&entsp=a&oe=utf-8&ud=1&access=p&filter=0&site=www_techdocs_archives
