12 years ago --- Quote Start --- Probably the same basic reason why dividing -32768 by -1 gives a value that is outside 16 bits. --- Quote End --- Ok. This would explain why I might exceed the output width of the calculated result, but not why a 32 bit input signal appears to be larger then the limiting 64 bits?
