12 years ago --- Quote Start --- I neither realize at first sight why the numerator should exceed 64 bit length nor what's the purposed of using the fixed point package for an all integer divider. I guess it's because you are using the fixed point divider beyond the intended number range. --- Quote End --- The above example should just show the problem with the port width. I am using true fixed-point integer later on.
