11 years agoDividing numbers by constants without dividers?
Hi! I would like to divide a number by a set of constants (3, 5 or 7) and I have read in an old post that using a divider might be a waste of resources. I have also read that for simple divisio...
11 years ago --- Quote Start --- Hi! I would like to divide a number by a set of constants (3, 5 or 7) and I have read in an old post that using a divider might be a waste of resources. I have also read that for simple divisions like the ones I need, it would be possible to use multipliers instead. I guess it would be something like this: N = 14-bit numerator (the number I want to divide) C = constant where C = {3, 5, 7} Result = N*(1/C) But I do not know how to get that 1/C in Verilog... Could anyone please give me an easy example? I would like to use an LPM_MULT so I would also like to know the optimal latency for a 178.2 MHz clock on an EP4CE10F17C8L FPGA. So far I have used an LPM_MULT to get a 14-bit result form a 10-bit and a 4-bit inputs and the latency is 2, but maybe I do not know if that would change in this case. Thanks in advance! --- Quote End --- The concept is this: suppose your input is x, coeff is y and you choose 14 bits resolution: c = c * 2^n/2^n; c = round(c*2^n)/2^n; the term round(c*2^n) you precompute it, call it y, then in design you multiply: x * y gives result, divide by 2^n i.e. discard n bits with/without rounding
