9 years agoDividing a negative number
Hi How can I divide a negative number by 32 ? without using a dsp ip core. thanks
9 years agoBy dividing the number by 32...
Division by a power of two is simply removing that many LSBs from the number, it takes no combinational logic what-so-ever. 32 is 2^5, so you need only remove the lower 5 bits of the number and the division is done. If you want the output width to stay the same, then for a signed number, simply replicate the MSB to fill the gap.
{{(5){a}},a}
Where "MSB" is the width-1 of the signal you are dividing. Alternatively, do an arithmetic shift:
$signed(a)>>>5
Will do the same thing. The examples I gave are in Verilog. I realise this is the VHDL forum, but I am not familiar with the language. There will be an equivalent in VHDL.
