DisplayPort Sink (Quartus 18.1) – horizontal pixel offset.
Hi Ven,
ad 1) DP1.2-VisionXG-Fibers(S), 4 optical pairs, HBR2
ad 2) When the image is shifted all MSA values stay the same.
ad 3) When the image is shifted DP Sink still declare video lock.
In the meantime, we found that CRC itself amplifies the consequences of the issue cause. When we removed CRC from the design the frames did not stay shifted. There is only 1 frame shifted and the following frames are correct. The damaged frame is indicated in changing of SOL/SOF, EOL/EOF signals on the DP Sink output.
Vilem
Hi vilem,
I sincerely apologize for the delayed response.
May I know which FPGA device family you are using (e.g., Arria 10, Cyclone V, etc.)?
As a workaround, would it be possible to implement the auto-reset CRC on glitch?
I understand that migrating your design from Quartus v18.1 to the latest Quartus v26.1.1 may not be feasible in your scenario. Based on your observations, I noticed that a new FIFO_ADDR_WIDTH parameter was added to the Clock Recovery Core in Quartus v25.1 (https://docs.altera.com/r/docs/683273/25.3/displayport-ip-user-guide/clock-recovery-core-parameters). If feasible, you may create a simplified test design and increase the FIFO_ADDR_WIDTH from its default value of 9 to 10 using Quartus v25.1. This increases the depth of the input FIFO in the Clock Recovery Core and help to accommodate higher-jitter input sources. Prior to Quartus v25.1, the FIFO was fixed to value of 9. Starting from Quartus v25.1, this parameter was exposed at the top level of the bitec_clkrec module, allowing users to increase the FIFO depth when dealing with higher-jitter input sources.
Ven
- vilem1 month ago
Dear Ven,
thank you for your reply. We use Arria V family. Is there any way how to use the new Clock Recovery Core (Quartus v25.1) in our Quartus v18.1 design?
best Regards,
Vilem
- VenT_Altera30 days ago
Hi vilem,
Thank you for your updates.
Unfortunately, there are no plans to backport this fix to Quartus versions earlier than v25.1. The fix was implemented starting from Quartus v25.1, and therefore an upgrade to Quartus v25.1 or a later release would be required to obtain the fix.
Ven
- VenT_Altera24 days ago
Hi vilem,
I would like to follow up regarding the update below.
As there are currently no plans to backport the fix to Quartus versions earlier than v25.1, please let me know if you have any further questions or concerns regarding this issue.
Ven
