9 years agoDisplaying Binary/Hex Output on VGA
Hi everyone, I'm currently trying to figure out how to display the output of a 10 bit multiplier as a number on a VGA. The multiplier is built up at component level using the block diagram meth...
9 years agoHave you tried or been able to display anything on the display via VGA? Based on your post I suspect not. You need to play around with something much simpler - what you're proposing is pretty involved. Yes, VHDL is a suitable language to use - I recommend not attempting to solve this using built in Quartus functional blocks. Try controlling the screen in a very simple manner first, then develop from there.
Cheers, Alex
