10 years agoDisplay numbers every second on 7-seg display using Verilog HDL and altera DE1.
I want to display different numbers on the 7-segment display of the altera de1 cyclone 2 board, but it has to be every second or every 2 seconds. For example at time t0 = 0s, number 1 should be displ...
10 years agoYou might want to search for "prescaler" this will generate a clock with a frequency that is lower than its input clock. If you do it right it can outputa frequency of 1 Hz. Use this to run the counter and the display part.
