10 years agoDisplay numbers every second on 7-seg display using Verilog HDL and altera DE1.
I want to display different numbers on the 7-segment display of the altera de1 cyclone 2 board, but it has to be every second or every 2 seconds. For example at time t0 = 0s, number 1 should be displ...
10 years ago --- Quote Start --- Generally I will use a counter with clock to introduce dealy. The "#" is normally used in test bench but not actual hardware design. --- Quote End --- Can you give me a simple example of a counter with clock?
