12 years agoDiscussion points....
Hi all,
So I've finalised my code for a uni project I'm studying. I'm currently writing up my report on how I developed my code and thought it would be good to end it with some discussion points/ideas for improvements. However because I'm new to VHDL I don't really know what possible points I could raise (I'm at the limit of my understanding!), and as I'm distance learning I don't really have anyone to bounce ideas off. I don't think I need to change my code as such, just discuss other options and say why they would have been better or worse. Does anyone have any suggestions? The code just sets a simple repeating pattern of outputs based around an up-counter, I've pasted it below: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use ieee.std_logic_unsigned.all; entity seq is port (clk : in std_logic; enable : in std_logic; reset : in std_logic; a,b,c,d,e,f : out std_logic); end; architecture behaviour of seq is signal count : integer range 0 to 5; signal vector : std_logic_vector (5 downto 0); begin process(clk, enable, reset) begin if reset = '1' then count <= 0; elsif falling_edge (clk) then if enable = '1' then if count < 5 then count <= count + 1; case count is when 0 => vector <= "001100"; when 1 | 5 => vector <= "011110"; when 2 | 4 => vector <= "110011"; when 3 => vector <= "100001"; end case; else count <= 0; end if; end if; end if; end process; a <= vector(5); b <= vector(4); c <= vector(3); d <= vector(2); e <= vector(1); f <= vector(0); end behaviour;
