User1573261788318367's avatar
6 years ago
Disable quartus_sh message output buffering
I've configured a Quartus Prime Pro 19.1 project using the GUI, and now I want to build it using the command line. Here is the command I've been using:
quartus_sh --flow compile my_project 2>&1 | tee quartus.log
The command line above compiles all of the project flows, and dumps both stdout and stderr to quartus.log. However, when I watch the command outputs during that command, the text seems to "hang" due to stdout/stderr buffering. Is there a way to disable the buffering, or reduce the buffer limit? Or just dump the flow outputs to a log file?
  • sstrell's avatar
    sstrell
    The compilation report automatically generated by Quartus should contain all the output of the compilation (output_files folder usually). Is there a reason why you want to output to a separate log file?
    #iwork4intel
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    Could you find the report file mentioned by sstrell?
    KhaiY
  • Hi sstrell,
    My organization uses Jenkins for regression testing and our default Jenkins configuration checks the output log every 15 minutes or so, and if there is no activity (i.e. no stdout/stderr) then it marks the job as a timeout failure. It's easy to disable this config feature but generally I would prefer to not have special exceptions for our FPGA regression.
    I am well aware that the logs contain all of the information, and where the logs are located.
    KhaiChein_Y_Intel
    I tried to run the same command and I can see that the quartus.log is written with the flow information using Pro edition software v19.1.
    Have you tried the same command using other project file?
    KhaiY
  • The problem isn't with the log or the project file. The problem is that when Quartus writes to stdout and stderr, it does so in a buffered fashion. I want the buffer to be flushed more often. We have seen similar problems with other tools before (notably Cadence Xcelium) and sometimes there is a flag to enable unbuffered writes to stdout/stderr.
    It's not really a huge issue, just annoying from a regression flow perspective.
    KhaiChein_Y_Intel
    Hi Ted,
    I recevied the reply from our developer today. I have sent an email to you. Please let me know if you do not receive.
    KhaiY
    • ArcticRain's avatar
      ArcticRain
      Can the proposed solution be offered to the community? I run into similar issues when compiling from the command line.
