Altera_ForumHonored Contributor17 years agoDisable Diode in Cyclone III Hi I have a Cyclone III with Vccio=2.5V and want to connect to a DSP with 3.3V Interface. As I understood AN447 I have to disable the diode in Cyclone III. But how can I do this? I read the Qua...Show More
Altera_ForumHonored Contributor17 years agoThe PCI clamping diodes are disabled by default, so no action is necessary usually.
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
