8 years agodirect DDR communication via VHDL/Verilog
Hello all, I would like to setup a kernel with an RTL library that directly access the DDR. This kind of work is illustrated here, in example 2: https://www.altera.com/support/support-resources...
8 years agoActually I have the same problem. So far, I can find all necessary modules, for example lsu_top in $QUARTUS_ROOT/hld/ip, and run module level simulation. But I don't understand how can the module communicate with BSP env, like how does the BSP knows when the function is stopped.
