12 years ago --- Quote Start --- It counts from 0 to 13 but i want it to count from 0 to 799 as the heading says about counter_int.h and counter_int.v --- Quote End --- May be. The screenshot shows a range 0..7. Why don't you show meaningful simulation results. Quite obviously, it doesn't change anything to the code behaviour when you place the counter signals in a record. I don't think that it improves code readability, but that's a matter of taste. Still no code tags used in your posts. :( P.S.: I don't know which phantom you are chasing. The code from your latest post is simulating fine.
