12 years ago --- Quote Start --- I don't expect a counter code like yours to count 0~12. The only connection is that 12 = 1100 and 799 = 1100011111 I have never used record type like you are doing and you may better avoid it as we are more familiar with say unsigned or integer type. so remove the record type and declare two counters as integers 0 ~ 799 or whatever and let us see. additionally avoid using multiple libraries. use numeric_std instead. I believe your counting logic is so wrong that most of it is optimised away givimg unexpected results. --- Quote End --- Thanks Kaz again, i have change the code in accordance with your recommendation. But i wonder why it still counts in the same way: i mean from 0 to 12 which is still not what i want. Any help please Library ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_unsigned.all; USE ieee.numeric_std.all; --USE ieee.std_logic_arith.all; entity VHDL_uppgift_8 is port( reset_n, CLOCK_50 : in std_logic; KEY : in std_logic_vector(3 downto 0); -- to the VGA unit/block VGA_HS, VGA_VS, VGA_CLK : out std_logic; VGA_BLANK_N, VGA_SYNC_N : out std_logic; VGA_B, VGA_G, VGA_R : out std_logic_vector(7 downto 0) ); end VHDL_uppgift_8; architecture VGA_ARCH of VHDL_uppgift_8 is --Kanske mycket tydligare (robustare) att ha en X och en Y unsigned med range. En record kanske är overkill, men kul att använda (se VHDL boken sidan 81). --using record type to involve elements with different data types --type HV_type is record --H : INTEGER range 0 to 799; --V : INTEGER range 0 to 524; --end record; signal counter_int_h : integer := 0; signal counter_int_v : integer := 0; signal clk_25mhz : std_logic := '0'; signal KEY_internal : std_logic_vector(3 downto 0); signal x : std_logic_vector(8 downto 0):= "101000000"; --X'320'--; signal y : std_logic_vector(7 downto 0):= "11110000"; --Y'240'--; begin VGA_CLK <= clk_25mhz; -- dett var något med att en klocka skall ut till VGA kontrollerns, kolla med DE2 manualen KEY_internal <= NOT KEY; -- Process to divide clock by two counter-- process_clock_25mhz: process (clock_50) begin if rising_edge(clock_50) then clk_25mhz <= not clk_25mhz; end if; end process; process_coordinate : process (reset_n, clk_25mhz) begin if(reset_n = '0') then x <= "101000000"; --Starting value on X y <= "11110000"; --Starting value on Y else if rising_edge(clk_25mhz) then if KEY_internal (0) = '1' then x <= x + 1; end if; if KEY_internal(1) = '1' then x <= x - 1; end if; if KEY_internal(2) = '1' then y <= y + 1; end if; if KEY_internal(3) = '1' then y <= y - 1; end if; end if; end if; end process; -- Process to generate Hsync an Vsync process_sync_screen : process (clk_25mhz) begin if rising_edge(clk_25mhz) then if reset_n = '0' then -- The next day the reset has been changed to synchronous reset counter_int_h <= 0; counter_int_v <= 0; -- Starting values for the outputs VGA_HS <= '1'; VGA_VS <= '1'; VGA_BLANK_N <= '1'; -- Pedroni says nblank and nsync must be kept at '1' and '0' respectively VGA_SYNC_N <= '0'; -- VGA_R <=(others =>'0'); VGA_G <=(others =>'0'); VGA_B <=(others =>'0'); else -- count h up -- Clock out RGB Pixel Row Data Horizontal Sync-- -- ------------------------------------__________-------- -- 0 639 659 755 799 if counter_int_h >= 799 then -->= counter_int_h <= 0; else counter_int_h <= counter_int_h + 1; end if; -- HSync Generation ('0')-- -- ------------------------------------__________--- -- 0 659 755 if (counter_int_h <= 755) and (counter_int_h >= 659) then VGA_HS <= '0'; else VGA_HS <= '1'; end if; -- 480 Horizontal Sync (pixel rows) Vertical Sync -- ---------------------------------------_______---------- -- 0 480 493-494 524 if (counter_int_v >= 524) and (counter_int_h >= 707) then counter_int_v <= 0; --(others => '0'); elsif counter_int_h = 707 then counter_int_v <= counter_int_v + 1; end if; --VSync Generation ('0') -- -- ---------------------------------------_______---------- -- 0 493-494 if (counter_int_v <= 494) and (counter_int_v >= 493) then VGA_VS <= '0'; else VGA_VS <= '1'; end if; -- This is when blank will be low(active) if counter_int_h <= 639 then VGA_BLANK_N <= '1'; else VGA_BLANK_N <= '0'; end if; -- This is when sync will be low (active) if counter_int_v <= 479 then VGA_SYNC_N <= '1'; else VGA_SYNC_N <= '0'; end if; if((counter_int_h >= x and counter_int_h <= x+3) and (counter_int_v >= y and counter_int_v <= y+3) )then -- white color ---------------------------------- VGA_R <= "11111111"; VGA_G <= "11111111"; VGA_B <= "11111111"; else -- No color ------------------------------------- VGA_R <= "00000000"; VGA_G <= "00000000"; VGA_B <= "00000000"; end if; end if; end if; end process process_sync_screen; end VGA_ARCH;
