12 years ago --- Quote Start --- your counting logic doesn't do what you want. at reset you set counter_int.h to 1 at 799 you set to 755 then you increment it in between. once it reaches 799 it will just go to 755 then 799 then 755 back and forth here is your code
if counter_int.h >= 799 then
counter_int.h <= 755; --(others => '0');
else
counter_int.h <= counter_int.h + 1;
end if;
--- Quote End --- Thanks Kaz, any logical tips on how the code should look, but what is strange is it counts from 0 to 12, even after i tried to modify the code. Is there something else that may be influencing the count?
