14 years agoNow the situation is the following one:
- with Synphony I manage to meet the timing constraints (by using retiming and advanced timing). It shouls use Synplify Pro to reach this result. - when I compile in Quartus I still do not manage to set all timing constraints specified in Synplify Pro format. In particulat I do not manage to find the node to which the define_multicycle_path apply. I used the node finder in timeQuest in order to do that. Anyone knows how to pass from Synplify Pro SDC constraints to Quartus SDC constraints ? Thanks Bye
