8 years agoDifference between RAM blocks and Memory Bits?
I recently encounter abnormal usage about RAM blocks. my code is like: # define A_PARALLEL 16# define B_PARALLEL 32 typedef struct{ float kk[A_PARALLEL]; } A_parallel; typed...
8 years agoI saw someone had same question as mine, the problem might be cached LSU.
However, after use volatile at __kernel foo(__global volatile const B_parallel *W, int count) still can't disable cached LSU... If I load data into local memory first, What is different between cached LSU and local memory?
