HugoStein
3 years agoDicrepancy between compiled projects in Quartus II Prime
Im trying to build a project that contains a lot of sub modules in quartus and, trying to debug the system because of a supposedly malfunctioning module, I found out that, if I compile the ...
- 3 years ago
Well if that indeed is your top level schematic, you have wired channels A...H and the trigger all to the same 16b bus.
So it is not surprising at all that logic is eliminated.
_AK6DN_
3 years agoWell if that indeed is your top level schematic, you have wired channels A...H and the trigger all to the same 16b bus.
